Engine/Transmission (1998.5 - 2002) Overdrive
2nd Gen Non-Engine/Transmission Help w/ AC.
2nd Gen Non-Engine/Transmission well, heres the plan for the Dodge
To overdrive or not to overdrive.
With the high cost of fuel now I'm looking for the best milage towing. With my old fifth wheeler I gross out at about 12,000 lbs.
In the past I've used overdrive on flat ground, 55-60 mph and not on hills.
Of course in overdrive its much quieter and better speed.
I have always understood diesels perform better at higher rpm and not being "lugged". Without towing truck runs great at @2000 rpm (70 mph).
Which is better, tow without overdrive or use it?
Planning a cross country trip and hoping to get at least 12 mpg.
My old 1990 would get 15 easy towing, but my 2002 is lucky to get 17 unloaded.
I just traded a 99, I couldn't tow in OD below 65 or the torque converter would slip/chatter. I would think that if you drive 55/60 that your fuel mileage would be as good or better out of OD. bg
