Trucks not going into od have usually 1 of 5 problems
kick down cable out of wack,
tps sensor
transmission temp sensor
od solenoid
lipseal on the od piston.
Kick down cable
basically controlls your throttle pressure
if your throttle pressure exceeds your governor pressure you will not get an od shift.
usually means your kickdown is set up too agressivly
before you rush out and adjust your cable forward, (more slack in the cable) keep in mind you are dropping you line pressure
REMEMEBER ACTION VS REACTION , the kickdown is the last think i would try to do to solve no od shift situation
tps
if the tps voltage is too low it can prevent a shift into od and or lockup
While some of you guys may laugh at this , anytime you add power to your truck you are affecting your tps sensor readings.
same as if you put in a tighter tc
What used to take you half throttle now may only take you 1/4 throttle, also if your tps voltage is too high , it can also prevent shifts into od and or lockup
If they worked with your pump and or your throttle cable they would have come in contact with your tps
trans temp sensor
if the temp readings are too high and or too low it can also prevent the shift into od
- od solenoid can be shorted or contaminated
- od piston lipseal can be damaged
Dont thow parts at it guys, too many variables.
Figure out the cause and then take it from there.
Tools you need if you are going to try and do this yourself,
digital volt meter, 7mm wrench or socket, pressure gauge recommended, a toggle switch and some electrical wires,
basically the above tools are to help diagnose the problem.
If you guys need a hand with it, get the stuff first and then call me. ( it will be helpful when you call if you have a portable phone so you can be by or under the truck. )
