Engine/Transmission (1994 - 1998) overflow valve inlet port hole....
2nd Gen Non-Engine/Transmission trans temp guage
Engine/Transmission (1998.5 - 2002) EGTs High When Towing a Load
I'm sure the one Precision Diesel sent is the wrong one, but I'd like to hear from you guys. The hole in the center of the inlet end (that screws into the injection pump) is quite smaller than my original. Will not work properly, right?
The # stamped on mine is 2417413093, and the one they sent is 2417413101.
When I called to order it, a fellow named Mike there said he had to cross reference it and he sent what he did. Input on this one?? Thanks. Mike (pita on this one)
I wouldn't worry about it. might help keep fuel pressure up
I was just going to say this my self... I know mine is a modified stock unit and has a hold just a little larger than a pin... . when I turn my aux fuel on when I am pulling it squeals and hisses at idle. Keeps the PSI up in the pump but am not sure how good it is on all the seals in there!
