Larry, according to the shop manual for my year, 2001, if you have the ignition key in the off position and then press the step and US/metric buttons at the same time, then turn on the key to ON, the display will go into a self-diagnostic test mode. The result is either a PASS, FAIL, OR what you saw, CCd. The manual says the CCd display requires a DRB scan tool to diagnose the problem so you might have to go to the dealer to have them look at it. It also checks all the display flourescent tubes for function. It also said the FAIL result means it is a goner so you may still be okay. Good luck and let us know what it was, we may be next! Thanks
