Overhead Console Blowing Fuses
center console sub box
Is it worth it!!
Friday out of the blue my 10 amp fuse that controls the overhad console and the 4x4 light in the dash blew. I replaced it and it blew right away. Is this a known problem with the 3rd gen? If so what do I look for. Thanks
#1. DC the neg. battery cables.
#2. Remove the overhead retaining screw. Should be only 1 screw.
#3. Using your fingertips, grasp the sides of the overhead console and pull straight down evenly to disengage the two snap clips and the rear of the unit.
#4. Lower the console enough to gain access to the wire harness and dc it.
#5. Remove console from vehicle.
To Install>reverse procedure.
crabman :)
Hey CrabMan... Thanks for that S/M link.
Hey SGBarracuda. After you drop the O/H console, unplug it and install a new fuse. If it blows again you know it`s not your console.
If the fuse fails again check the wire harness from the console down the left A pillar. Disconnect it at the junction box by the left kick panel/firewall area. Try the fuse again.
If it`s OK after you have unplugged the harness from the box at the fire wall, it`s most likely in the A pillar/headliner area. A wire has chafed through.
If the fuse remain good after you unplug the O/H console, look for damaged wires at the mounting screw locations before you condemn the console display unit. Hope this helps. Post back and keep us up to date. :)
