overhead console light
Serpentine Shift Revisited
Lift pump repair kit?
Anyone know how to access the drivers bulb in the over head console with trip computer? I see no screws and do not want to break any hidden clips.
Rocks
If you open the compartment for the garage door opener there you will see two clips. By putting your hand at the front of the console pull back and down while popping the clips with a screw driver. Put the screw driver between the clip and the console towards the rear. once the front drops down slide the console towards the rear about an 1". Good Luck
Thanks, I did not find that in the procedure for removing the console in the book. I was looking for dome light and the book calls for reading light. The bulb actually fell out of the socket,
