I'm installing dual temp and combo boost/egt gauges above the mirror on my '05. Anyone know which wire to the overhead module is for the dimable illumination? black/white is supposed to be ground, PK/DG is supposed to be fused ignition output, White/violet is listed as PCI bus, whatever that means, and red is listed as fused B(+), which sounds like constant 12 volt.
Thanks in advance!
Thanks in advance!
