I haven't posted in a while because my truck just runs and runs well with the Smarty. About 2 months ago my temp gauge started getting jerky and would show the truck run hot and then pop back to OK and then heat up and then pop back all within a few miles.
Another 07. 5 manual was doing the same thing and they ended up replacing all of the hoses, fluid, thermostat and water pump. Before replacing he parts they would stop the truck and let air out of the radiator when it starting acting up. The truck would go back to a normal temp for a while. When the temp gauge would act up they repeat the step above.
Well, I started going through letting air out. Then we replace the thermostat which was bad with another bad cheap one. While replacing the second thermostat we replaced all 4 hoses and the fluid. Within 250 miles I had boiled all the water out of the radiator again.
So, anyone else have or seen this problem? Know the fix or the issue?
Smarty is running 21ME on setting 1
