I'm bouncing this over from the 1st Gen forum. I recently developed a leak at the water pump seal: The symptoms were coolant spray sourced to the junction of the lower lip of the water pump to block mating surface-not the weep hole. The temp gauge was fluctuating at that time but not overheating and I had cab heat. I replaced the water pump and seal (new from Cummins) which stopped the leak. Now - no leaks- but the truck overheats within 10 min of driving, there's no cab heat, the rad hoses remain cold when the temp gauge is pegged, seems like no flow thru the motor. I replaced the thermostat with no change. Obviously I'm having a craniorectal inversion on this problem...
I need to get 200 mi into west texas to do some welding ASAP and I'd rather not have to rent something and transfer all my crap over... any ideas out there?
Many many thanks,
kad
Many many thanks,
kad
