Ok, so say I want to sandwhich my frame with a bracket for air ride. The bottom and outside of the bracket will be one piece. The bolts will go through bracket, then the frame (both sides), then a "strap" to spread out the bolt tension
Kind of like this. The catch is, the weight will be sitting on the bottom of the bracket also. The bottom of the "L" would be sitting under the frame.
L [] I
Should I try to drill the holes just bigger than the bolts, 5/8" Grade 8, to 3/4" or can I go bigger? The bolts won't be doing any weight supporting. I am a fairly good machinist but probably can't drill a straight hole through a box frame, which the oversize holes will help me with for getting the bolts straight.
Thanks!
Nick
L [] I
Thanks!
Nick
