2nd Gen Non-Engine/Transmission Oversized Rotors?
Engine/Transmission (1994 - 1998) speedo acting funny
Engine/Transmission (1994 - 1998) Plate or injectors?
I have a 98 2wd and thinking about getting 19. 5" wheels for it. Are there any larger rotors That I can install behind these wheels for better braking power? Maybe larger brake drums too. Thanks for any input.
Dallas :) :)
oversize rotors
Dallas:
Not that I know of, I like the EGR and EBC rotors (oem sized for diameter).
You might try DC to let you get some measurements off a hub rotor for a third gen truck, then you could get 13" rotors? Not sure of the backspacing or wheel bearing, spindle arrangement. .
You would also have to modify the caliper bracket and likely go the the third gen caliper. .
Sounds expensive and lots of r&d.
I would ck. out the EGR or EBC rotors both are pricey but work as advertised.
Good luck
Andy
Thanks for the reply Andy. I will check into the info that you sent me. I have a lot more time than money. Thanks again.
Dallas... :) :)
