CP98. Was that picture looking down at the top of the IP with the intake/head removed? If so, is there any chance it can be seen with a mirror? Also, you mentioned the throttle shaft seal. Is that a DIY or a pump shop. The oil consumption I posted about previously has become major in a hurry. Oil is dripping from the starter and prefilter and the left side of the engine is soaked. It used a gallon in 700 miles. I think it is mostly blowby, but once I clean it I want to check out other possibilities. I had to tow a big square, heavy trailer into the wind and was in 4th gear at 2400 rpm and 17-20 pounds of boost for quite awhile. On the way back I lost 5th gear and had to drive about 500 miles in 4th to get home (2500 rpm = 60mph). Used a little over a quart for that.
