2002 3500 ETC P-ECU 0216
Started in central FL at start of 3 week vacation.
Had dead pedal for about 2 seconds after being on the interstate for about 2 hours. Fuel pressure has always been good.
Went to RALLEY Dodge in Ocala they replaced LP (at the godness of their hearts as they put it).
Drove next day through serious mountains. Power was good. Fuel pressure was good. Went dead pedal again as we pulled into campground.
Same code P-ECU 0216 (they had cleared the 0216 code, I checked that they did).
Took it to Dodge dealer in Montecello IN (where we are now). They diagonsed it as Camshaft Position Sensor. That is going to be replaced tommorrow.
I called a Tavel Companion member and they felt it really is a VP-44.
Could it be a Camshaft Position Sensor (ie could this dealer be right or are they just closer?)
I SURE could use some help here.
All other engine indications seem normal. When coming through the mountains outside Chattanooga it was developing 35# boost, good fuel psi, good pulling power on long uphill grades.
Hesitaton yesterday happened when we pulled into the campsite at low power (barely above idle)
THANKS in advance,
Bob Weis
THANKS in advance,
Bob Weis
