Diesel85
I got a P006D Barometric Pressure - Turbocharger/Supercharger Inlet Pressure Correlation code on my 2020 EcoDiesel.
I tried replacing the MAF sensor thinking that was the culprit. Did not fix it and I returned the new MAF sensor so I didn't lose money. Reinstalled original.
Along with checking the air intake hoses and CAC hoses for tightness. I did not pressure test the system. I'm also using a genuine MOPAR air filter right from Geno's.
Code is repeatable. Cleared the code and it comes back after about 3-4 starts/stops. No cool down/warm up cycle needed.
Truck is getting the usual 27-29 mpg for my commute.
Looking for someone to take a stab as to where to look next. Maybe the MAP sensor? MAP sensor always shows 28.7 inHg when the truck is turned off. The MAF sensor is showing 31 inHg and the Turbo Baro sensor is showing 29 inHg. Not sure if that MAP sensor is way off showing 28.7 inHg with the truck turned off.
Attached is the freeze frame data.
Also, the truck is under warranty, but if I can fix it myself for a cheap sensor problem, I'd rather, because I get satisfaction out of it and I learn a lot. Not going to take half the engine apart to fix it or disturb more things that would cause flags. If it's in my face, then I'll do it, otherwise, I'm leaving that for RAM to figure out.
Some folks said I already did too much troubleshooting for a warranty fix. I have it scheduled on 8/8 for it to be looked at.
