P007E code?
Engine random rev up while at cruising speed.
Cooler bypass valve failure
What is the most likely cause of this code? Check engine light is on with this code. P007E "Fuel Air Metering"
"Auxiliary Emission Control". Engine starts and runs fine.
Did a search and came with with nothing.
Thanks
Jeff.
I found this listed for that one.
Symptom Descriptor
Charge Air Cooler Temperature Sensor Circuit Intermittent/Erratic
Probable Causes
Charge Air Cooler (CAC) Temperature Sensor
The 5.9 and 6.7 show to be different sensors, not sure which one you have.
The code is listed the same under each engine.
