P0118 and performance changes
Transmission Problem Again-Suggestions Welcome
Can someone confirm this is the correct ds part?
Does anyone know if there are any default engine management strategies associated with P0118, engine coolant temp sensor voltage too high? I haven't cleared the code yet as the engine feels way stronger like it is fueling "better. " Just thought I'd see if anyone else has experienced this kind of behavior out of their rig.
Not sure on that one. I have been having some issues one of them fueling which I believe has been fixed. The fueling issue I am refering to. I changed so many sensors and the ecm that I am not sure which one fixed it. The coolant sensor was one of the sensor I changed last week though. It was only around 9 dollars at cummins so it was a no brainer. Sorry I couldn't be of much help to you. Change the sensor and if the truck is slower put the bad sensor back in. Lol
