Details here: TDR Privileges
I have a P0201 code after installing a TST. I ran a check on this site but have only found it for a 2003, Im not sure if it is the same code for my 2004. 5
Ive figured out that Yes the 2003 codes apply and that it is a ckt 1 problem... I am also now getting a P2146 code which also deals with a ckt 1. Does any one know which plug is for the ckt 1 injector? The front/center or rear set of electrical plugs?
I'd double check all your connections, paying close attention to the cam and crank sensor connections. All it takes is one bent or misaligned pin to screw things up.
Also run the ground wire into the cab and attach it to a screw on the dash... That helped with my codes... I still get one from time to time but its just the way it goes i gues...
Does anyknow which ciurcit is the #1 for the injectors? Im about to eat, then go mess with the plugs. I think I will go ahead and run my ground to the cab. I read in the instructions that I might want to do this, anyone know why it is better?
