Truck runs fine when cold after it warms up, it quits when going into reverse or drive(unless you keep the RPM's up. Had the 0216 code. the dealer replaced the Pump and lift pump. No help, but the new pump had a new p 0216 code so he replaced the pump again. same problem again but ATTM no code. He thinks it might be fuel. I don't or every Dodge in Alaska would be in. I had a factory program loaded into it 5 years ago so when it gets cold it shuts off 3 injectors and raises the RPM's to 1200
Anyone else have this an what was the fix.
