P0237 and no oil pressure simultaneously?
Instrument panel bulbs (low wash, seatbelt)
Radio Replacement
Hi all,
Drove the truck all day today (did fine), but tonight when I started it to leave the grocery store, saw no oil pressure on the gauge (briefly worked again for a second at one point) and had check engine and check gages lights come on. The code was p0237, and the turbo wasn't making over 10 pounds of boost. I checked the ground and connections at the pcm, and they appear to be okay. I did the self check for the gauges, and they're all moving fine.
Is this a pcm thing? It threw the boost code and the oil pressure gauge stopped working at the same time. Not sure where to start. I do have an edge ez, so that complicates things a little.
As a side note, the in gauge cluster diagnostic showed p1693 and p0122 (but no p0237...), but the apps hasn't acted up in months since I reset it. Not sure if this is related.
Thanks!
