Take a look at my sig for truck stats. I recently had the DTT transmission and the Mach 2 injectors put in, combined with my DDTTPM, which I previously owned.
Edit: BTW FP is 14psi at idle and 8-10 WOT.
Original Problem: driving steady at 70mph, then I would push the accelerator down, at which point the truck would fell like it was missing.
Test: Take box off. Problem seems to go away.
DD exchanges the box for me no problem.
Then I clean and dielectric all connections, and plug new box in. Problem doesn't go away and now the MIL illuminated (check engine light), which ends up throwing the P0237 DTC.
I do research and it seems the MAP is to blame. So I replace MAP, keep box and boost elbow off, let sit with battery cables undone for hour. Reattach and recalibrate APPs. (actually I've done the APPs recalibrate twice now)
Problem Now: P0237 Code will not erase and accelator feels very sluggish, at times seems delayed response.
Does the APPs throw codes? Any ideas? How do I test the voltage of the MAP?
Thanks
Dish
Thanks
Dish
