P0606 after smarty DL
Starter Removal
engine runs rough after driving awhile
Just put truck back to stock and CEL comes on, P0606, didnt know what that was so I fire it up and drive it 40mi, started out surging just a bit and sluggish throttle response for maybe 1-2 mi then cleared up all good runs fine, got home and hooked up smarty and tried clearing that code and a P2A00 which is O2 1/1 what ever the heck that is? I know but I don't anyway neither will clear and truck runs like normal. Should I put tune back on? Wth?? Everything way better when tune is on, maybe has nothing to do with it but I had codes before that wouldn't clear till I downloaded tune and it ran like a scalded cat.
You can load a Smarty tune but if it has all of the emission equipment now on the truck it must be an emission compliant tune. The ME tune will cause you issues with the truck and the DPF.
The emission compliant tunes will state that they meet the US emission rules. Such as this one: S67V619l DRS01M.7z. REVO software This is emission legal software
Jim W
Doesn't going back to stock tune after having previously set @ 3mild & timing @2 what a beast doesn't mean what it says, "stock" ? All engine and emissions stock from factory? or doesn't it work like that? I'm still learning @50 haha
Depends on which "stock" option you select.
Selecting 0 (zero) while running a delete (me) tune gives you the stock power with deletes tune. (Dpf and egr deletes)
Selecting X returns the ecm to the stock tuning and unlocks (uninstalls) the tuner. (Stock exhaust and emissions equipment installed)
It does say what it does in the manual.
I talked to the man who sold it to me and he said as soon as I programmed it the deletes automatically happened cuz of the "me" , that is what I didn't know because it does not say it has done the deletes as the smarty does not tell you. All is great now, thanks for the info.
