P0837 - I know what it says, what does it mean?
Smarty Jr. timing rattle
Starting problem
I have a P0837 code listed out on the odometer, the only code listed. I know this code is labeled, "Four Wheel Drive (4WD) Switch Performance / Rationality". My question is, what does that mean? As far as I know the four wheel drive switch is functioning properly, it switches in and out of 4WD OK when I move the lever. So, what symptoms should I be looking for? Anyone had any experience with this code?
Thanks,
Jim
Thanks, I'll check into those things when it warms up a bit. It doesn't sound like it's the kind of thing that would require immediate attention. <g>
Jim
It will be a soft code. If it doesn't get the fault again within a certain # of key key counts (10 I think) it should clear itself. Don't quote me on the amount of key counts.
