P0839...
Any tire w/more ld rating than stock?
06 seat question
... WTh does this one mean?? :confused: Buddy looked it up on his Snap On scanner and said something about aftermarket scan tool errors and dealer only tool needed?? Any ideas? I 'm thinking it is tied into my brake and ABS lights coming on at will.
Here is what 04 Power Train Diag manual says
Symptom:
P0839-4WD MODE SENSOR HIGH
When Monitored and Set Condition:
When Monitored: Continuously with the ignition key on.
Set Condition: When the 4WD Mode Sensor input circuit voltage raises above 4. 78 volts
for 5. 72 seconds.
POSSIBLE CAUSES
TRANSFER CASE POSITION SENSOR INPUT CIRCUIT OPEN
TRANSFER CASE POSITION SENSOR INPUT CIRCUIT SHORT TO VOLTAGE
POWERTRAIN/ENGINE CONTROL MODULE
INTERMITTENT OPERATION
Any idea if this could be tied into my ABS and brake lights lighting up at will? :confused: Thats when I was able to pull this one, right after they came on. Thanks again!! :cool:
