I hope that someone can help me out here. When I start my 1998. 5 dodge sometimes it will rev up to 1500 - 2000 rpm's on it's own and than come back down to an idle. With the flow chart through alldata for p1689 i tested the wiring and pinpointed to and ecm. Purchased and ecm and replaced it but truck still has problem. Just replaced injector pump with rebuilt, and truck still has the problem. Double checked wiring and still checks ok. Cleaned battery cable grounds, but still I cannot figure this out. Please help if you can. Truck has edge ez with tst stacked, dd stage 3 injectors, hx 40 turbo. Tried with tst off and pump wire off, but still has problem. Also has new apps.
Thanks, Steve
Thanks, Steve
