P2000 ???
Rail Pressure
Anyone using Bio Diesel in 08 6.7s
Is this code anything I need to go back to the dealer for ? I looked it up and it has to do wit an oxgen sensor. I have one flash done to my truck when dodge sent me a notice in the mail. I belive it had to with the oxgen sensor also. Is there a need for a newer flash I can't remeber the one I have is the G30 I think. I also have these codes 0581 and 0593 Has something to do with speed senosr voltage to high???? Im hoping that the p2000 is enough to get me the new flash that some say is improving throttle responce on the six speed manuals.
I have gotten this code more times than I can count. You will need to go by the dealer and let them clean your oxgen sensors and get the latest flash.
There is apparently a cal change coming which will fix this, but like JRader said make sure you have the latest flash and the dealer will clean your O2's. The good thing is this code doesn't cause any issues with regards to power, regen, or anything important... . It is just a pain to keep seeing the check engine light.
I hope you're right, my P2000 code is back, again.
