RWeatherbee
I have read the other post in this area and not sure if the problem is in my ecm or not. Truck has only 58000 miles and is stock except for the muffler. I have checked all the resistances and injector #'s 1, 3, 4, 5 and 6 all read .5 ohms. #2 however reads .7 ohms. I have measured continuity from the ecm connector all the way through the solenoid and back to the connector and still have only .7 ohms. The truck did lose power and the light came on. The fact that number two reads higher than others but below the 1 ohm cut off makes me believe the ecm is at fault. I was wondering if anybody else has experienced this problem with injectors that are within tolerance required but still bad.
