P2121
Aisin Transmission Filter Change
Which coolant?
I have a 2013 3500 with 856000 kms Recently I replaced injector pump and pedal assembly as I was getting P2121 code and low fuel rail pressure. The p2121 code is on again only when I am hauling a trailer and when not works fine. When hauling trailer the engine light
comes on and lost of pedel I then down shift to 6 then 5 and the engine rev up and it works fine and light goes out Any clues to look for
P2121 as you know is associated with the throttle pedal, could be bad or could be a bad harness or bad connection, also a possibility it is in the ecm.
You need someone with a dealer level scan tool or the factory WiTech scan tool to be able to see what is going on.
