Ever had this code be temperature dependent? Haven't had this code for a year or so. The first warm weather and it popped up. It turned cold again and it gone. Wouldn't this like be a connector problem in the engine compartment?
I want to unplug C130 (or is that C331?) on the firewall and C1 and C2 at the ECM. Some questions on doing this properly.
1. I assume I should disconnect the Batteries first, True or False?
2. Should I not try spraying the connectors with cleaner BEFORE disconnecting them?
3. C1 and C2. Don't I have to remove a nut or screw in order to disconnect? They are hard to get to and I can't quite see whats down there. Personally I have to disturb them being 10 years old. Seems like asking for trouble.
4. Once connectors are disconnected what is the best maintenance procedure? I would assume to spray with contact cleaner and reassemble or is it appropriate to add some lube to the connector as well.
PS I have an 06, 3500, (diesel of course)
