Just wanted to post my experience as it seems different then most.
My 04. 5 listed in my sig was showing a P2149. Truck lost all power and was only running on 3 cylinders. No other codes present. Started with a wire harness inspection for any wear or rodent damage. Nothing present. We then pulled the valve cover and inspected/tested the Injector harness that connects from the 3 plugs outside the valve cover then to each injector. Ohm tested fine.
Then Ohm tested each injector. Injectors 1,2,3,5,6 all tested . 3ohm. Injector 4 tested 0 ohm. We only could assume with all injectors testing the same and the odd ball being #4, that is where we should start. Most would say that a bad injector shows a high ohm reading above 1ohm. This is true for most cases. In my case it was not. The ECM was shutting down the 2nd bank(4,5,6) so that the faulty injector would not damage the ECM.
I sourced a Bosch Re-man Stock Injector. Replaced #4 Injector and put things back together. Fired the truck up and it runs smooth as new. Cleared the 2149 and all is well.
Have to thank my Friend and local Cummins Tech for diag and replacing the injector.
Lyod, Lmills was also a great help! :-laf
