NIsaacs
I am working on a 1998 12 valve with a major oil leak between the gov. housing? and the main case. It is the rear most housing type cover on the back of the Inj. pump, I think it has the governor and throttle inside. I have it loose but it still seems to be attached to the throttle shaft?? I don't see where or how to disconnect it so the case will slide off. It moves about 1 inch or so back as the throttle shaft rotates but stops when the shaft stops rotating.
Am I already in to deep for a non bosch repair person or is this doable for a normal mechanic?? The pump is still on the engine so it is hard to really see what is going on inside the housing. Any help would be most welcome, even if it is to say, I should have stayed the heck out of it... :-laf
Nick
Nick
