Does anyone out there know anything about the P7100 Injection Pump? I just had a rebuilt one installed and the truck ran great for a few days then all of the sudden I lost power. By that I mean initially boost pressure would jump up immediately and the old girl would belch out black smoke and go like a bat out of hell. Now boost builds slowly, no black smoke and no get up and go. How can I check the diaphragm on the pump to see if it is ruptured? I would presume that one could put some pressure on it and do a drop test.
As I am a new member and unaware how one closes out a request for information let me post this:
All checks of a leak showed none. I then decided to check the turbo itself. Having had the turbo rebuilt some time ago I did't suspect the obvious, that IT could be my problem. In examining the rotor at the air compression side I noticed a LOT of up and down play. I believe this excessive play is preventing the turbo from spooling up as it should. If you don't get enough boost to the Aneroid it won't give you any more fuel. I purchased a new HX35 today and will install tomorrow. I think this will solve the problem, besides as of today I am 500 miles short of a million on the old one I guess it's about time to buy a new one, you think??
