Where are the fire breathing ponies that the P7100 pump is supposed to deliver?? I converted my VP44 to a '913 P pump with Piers 4000rpm GSK, 0 plate and just over 20mm rack travel. With small injectors the trucks runs about like is should if you were going to loan it to your brother-in-law
and it runs fairly strong with Bully Dog 8 injectors. Would guess that I'm down 100-150 hp from the VP44 with proven electronic enhancements
. Engine runs smooth, pulls to 4000rpm, smokes alot (off boost) but the power is disappointing. I know that I need more fuel pressure as I'm still running the ISB custom system at 25lbs and can pull it down to 20lb fuel pressure on a long run but even if I shut down one pusher pump (less pressure) it doesn't affect power much.
$3000 race pumps may only be considered if donated, remember reman'd VP44's are less then a grand. Any ideas??
Larry
Larry
