Hey you Pump tuners... ... .
I have a 4KGSK in my pump and a #5 Plate 215 Injectors and now all of a sudden, no Idle. I ran through the gears on a back road yesterday and held it in 2nd for a while (3500 rpm) then on th 3rd, etc. All seemed fine until I got to the next stop sign. Viola, no idle. I can keep it running with my foot, but not by itself. Whats Up?????
I rechecked the gov springs for a broken one or mis adjustment. That is all OK. I set the idle up and now it will idle at about 1k if I put my foot on the throttle to start it. When I put it in gear I have to keep it running with my foot or it dies.
The engine sounds fine and runs fine off idle. I suspect that there is an internal setting (?) that gives the fuel to the engine when you load it with the transmission. That must have stopped working.
Any suggestions that you guys know of?
Thanks, LaserBob
Thanks, LaserBob
