Engine/Transmission (1994 - 1998) P7100 Oil Leak
I discovered an oil seep coming from the injection pump. The leak is a solid seep (no breaks) and coming from the lower left corner of the access plate (see pic). I am finding it challenging to find the seal without buying a seal /rebuild kit. Any one have a lead on where I can get just the seal?
My current plan is to remove/reinstall with gasket seal and get rid of the straight slot pan head type screws and install same thread/length bolts as well. any thoughts suggestions please chime in. . . thanks as always!!!!
The plate is just thin paper gasket. There is only splash lubrication within the pump so it is not high pressure.
Also check to make sure all the screws are still there. I had a leak that was caused from one screw falling out. It was right above the throttle input lever. I replaced it and used a little silicon on the bolt threads. No leak to this day.
Thanks for ur reply J. The seep is def coming from the lower outboard corner. I will check all the other hardware as well. On the road currently.
D
