Details here: TDR Privileges
My guess is the noise is coming from the lift pump. Over time the internal spring gets a little weak and the pushrod loses contact with the cam for a millisecond on every revolution, causing a tapping noise. How many miles has it been installed?
Thanks for jogging my brain.
Did not consider lift pump - will order pump, elbow hose and upper gasket.
For the price it's worth finding out.
Will let you know in a week or two.
These pumps have been changed in the past and are quite for a while and then the tapping comes back. Its what they do. I wouldn't worry about it. After having done it once.
Get the studs and put them in first they help a lot with installation.
