Engine/Transmission (1994 - 1998) P7100 pump numbers
Engine/Transmission (1994 - 1998) Wastgate
Engine/Transmission (1998.5 - 2002) Can I remove filter housing?
Does anyone know of a web site to decode p7100 pump numbers? Or can someone on here tell me? I found a pump but wondering what it came off of and what HP rating it is.
numbers are as follows:
rear plate:
927
RQV350... 1100PA96-1K
CDC NO. 392 1771
side plate:
927
36721922
0 402 736 807
PES6P110A120RS7214
Although the 8. 3 pump will physically fit on a 5. 9 there are of course many differences. One of the main things is the oil supply. The 5. 9 uses an external oil line while the 8. 3 gets its oiling from a hole in the gear housing which goes into a hole in the front of the pump. To use an 8. 3 pump on a 5. 9 you would have to use the external oiling line and not all 8. 3 pump housing are drilled for the fitting for the line. Then there are all the internal differences. In a nut shell its much easier to modify the stock 5. 9 pump , especially if it is a "215" pump, to gain horsepower than to play with something that wasn't ment to be on there in the first place. ( not that anyone here ever does that :-laf ) Shadrach
I've heard the 8. 3 pumps are also set up so differently you wouldn't even want to try and run one on a 5. 9, and it would be a job to make it work. Not sure if that's true though.
ive heard they are a bit of work. i eneded up not getting the pump, i kinda wanted another one to play with and figure out what goes on inside, and rebuild for a back up but, its hard to find a 215 pump for a reasonable price. But after the 12v conversion ive done moding the 8. 3 pump cant be any worse!!
Shadrach, i got some more numbers maybe you could check out for me? Found another pump but the guys not sure what its off of either.
PES6P100A320L
NP 3281
RQV35-1400LXP3281/1K
Thanks.
The numbers you supplied are incomplete to decode. There should b a tag on the back of the pump and another on the side away from the engine. The Bosch numbver has 10 digits -x xxx xxx xxx and the Cummins has 7-39xxxxx The first pump you found the Cummins number was 392177 and the Bosch was 0 402 736 807 Shadrach
those are the only numbers on the second pump, it has a Robert Bosch USA tag on the back of it but only the one number on it.
