I would be interested to know if any one has had a 7100 pump fail because of the new ULS diesel. I have a customer who owns a 94 2500 auto with 177,000 miles which had a sudden shutdown, followed be a restart then repeated die and start. (I owned this truck until 156,000 and had no problems. ) The fuel shutdown solenoid is ok, transfer pump pressure was 3# to 30# on a come and go basis. So I replaced the transfer pump & filter (Fleet Guard), cleaned the heater screens, which were almost perfectly clean. And we now have 23# at idle up to 41# at higher RPM and it is stable. It started and ran fine until fully warmed up then the same problem returned. #3 cylinder starts missing and the corresponding pump cylinder starts to tick or tap, sounding much like a loose tappet on an old 235/6cyl chevy engine. Also the throttle will stick, not the linkage but the RPM will be very unstable and high idle then low idle then die, ect. If you are driving it will loose power, then it dies. After restart it will try to run then do the same sequence again. Let is cool off and it runs fine until warmed up again, but it will set and idle all day with no problem if you don't put a load on it. It has had power service lubrication additive in the fuel, but only on an every so often basis. At this time it has a heavy shot of "Howell's Lubricator" in the fuel, but no change.
My concern is that the ULS fuel combined with the "no-to-low" fuel pressure caused by the tired transfer pump has caused a problem with the upper end of the injector pump. I thought (hope) some of you pump guys may have seen this if it is a problem.
We do have a fuel sample on the way to the lab because of the possibility of vandalism where he works.
Also, we are looking at replacing the '94 pump with one from a '97 5 spd. Does anyone know if the '97 215 pump will work with the '94 160 injectors?
If you have seen this done I would like to hear from you, or if you have seen a problem like I described above.
