Just wanted to drop a line about the Viair compressor that Pac Brake used to use! I have an 05 Dodge 3500 that I have had the Pac Brake in since 2006. The system has worked pretty much flawlessly minus some freezing up issues where I had to move the activation switch right off the pump until recently when the pump quit on me.
The pump would run and hum but no air. After taking the pump off and calling Pac Brake they told me that the Viair pump was obsolete and could not be rebuilt that I needed the upgrade kit at at cost of $260! I took them at there word and bought the upgrade kit! This is where it gets good. Like anyone who forks out good money for such a product I took the old pump apart to find that the crank and piston assembly was broken. I contacted Viair and the pump is rebuildable! For $30 I bought a replacement piston and took the time to install it and the pump works like new. I contacted Pac Brake about this and explained that the pump was rebuildable and wanted some kind of price drop for the new setup I was told I needed and they went on about how I got the new pump setup for well under list price. Wow, a company who stands behind there product. Oh and Pac Brake went to a Puma pump!
So the moral of this post is that if you have a Pac Brake with the Viair 275 pump it can be rebuilt and you don't have to spend the money like I did I hope that this saves someone else some money!!
