2nd Gen Non-Engine/Transmission Pac Install Recommended air tank spot
Engine/Transmission (1994 - 1998) New DTT is on the way!!!
Engine/Transmission (1994 - 1998) Really poor MPG
How big?
I plan on adding 1 small & 1 large hadly tanks for air horns & air. What I will be going to do soon is to pre mount them on a plate with the compressors, solenoids, etc. I would weld two bolt heads (to end up with 2 studs), on the frame inside drivers side near the transmission because it is wide open. This section of the frame is boxed or else I would have just used the bolts. By having a plug on the wires simple cleaning, repairs & changes can be made on the bench and not under the truck. hope this helped.
Thank you - It came with a half gallon tank, seems kind of small though as I would like to add air horns too. I will get under and check it out tomorrow.
Thanks again.
