Engine brake works sluggish and intermittent.
I pulled the two hoses from the solenoid.
Pulled vacuum on the hose from the bottom of the vacuum canister. Vacuum retracted the shaft, and then it held vacuum.
Attached vacuum to the top of the canister. Vacuum extended the shaft, but would not hold vacuum.
I called pacbeake for help. The tech asked me to plug both hoses and try moving the shaft in and out. Should have been very difficult to move the shaft.
The shaft moved easily in one direction but held firm in the other.
Tech said the vacuum canister was worn out and needed replaced. $170 ish.
Anyonse else done this?
