There have been lotsa threads about exhaust brakes, but I'd appreciate comments on the following:
(1) PacBrake air compressor failed a bit out of warranty. Installed 4/8/04 & failed 2/20/07 to the tune of $574.
(2) On the new compressor, apparently the installer (Henderson's Line-Up Grants Pass, OR) carelessly allowed the plastic air hose to touch something hot. Manifold or ? Regardless, the hose failed on 7/31/07 (5 months later). No Charge.
(3) The hose failed again on 5/16/08. Appears that Henderson's may have used what they thought was the good part of the original hose as there was about a 2 inch "line" down the hose that appears to have previously been against something hot. This is where the blowout failure appeared.
(3) I was able to make a "field repair" that enabled me to get down the Siskiyou grade (I-5 northbound) with a brake, but I need a replacement hose that is properly ferruled. I'm surprised that my repair worked at all. Without equipment, getting the ferrule back on is pretty much impossible.
Questions: (a) Is the black hose supplied by PacBrake OK as long as it's carefully installed away from hot metal? (b) Would wire loom or some other protection be helpful? (c) Is there a better hose?
The bottom line is I really like the brake, but I need it to be more reliable. Due to a family circumstance I only have 18,000 miles on my 2004. 5, so it's not like the brake has been over used.
Thanks,
Jim DeMont
PS. The truck itself has been fine. Only time back to the dealer was for the early on white smoke - mileage reflash.
Thanks,
Jim DeMont
