Pacbrake PRXB exhaust brake on sale this MAY.... $250 rebate from Pacbrake
47/48RE 2wd Overdrive Housing Support Brace?
P2127 back again - sort of
The brake assembly itself is pretty quick and easy. I don't know where they mount the compressor now but mine, 8 years ago, was mounted just in front of the intake air grid heater. It stayed there for almost 8 years until I decided to mount a larger compressor under the passenger door under body. If you have an automatic, I did a real nice option for a client of mine. I took an old style headlight high/low beam foot switch and mounted it on the upper left foot well. He could actuate the brake on and off with the foot switch. The PRXB is turned on and off with switching a ground lead. So I grounded the center position of the high/low beam switch and then hooked the PRXB to one of the two remaining terminals (High or low terminal) He loved it! Mine being a stick shift, I installed a two speed rear axle switch on my stick shifter.
High/Low Switch: http://www.ebay.com/itm/Fits-Chevy-...ash=item462a2682f3:g:x6gAAOSwU9xUNtJx&vxp=mtr
2 speed axle switch: http://www.ebay.com/itm/FORD-2-SPEE...ash=item3abd9d3fab:g:aCcAAOSwFqJWmyZR&vxp=mtr
