Hi Guys,
I have a question and the statement above my be wrong. The pacbrake still works but not with me using the normal switch, see I did some trouble the other day and I can jump out the solenoid valve and the pac will close.
What is the two wires come or going from the PCM I know these are the two wires which closes the circuit from the switch inside the cab. I did check and I have a code P-0477 show and can not reset this from turning on/off on/off on/off the ignition switch.
Is this the reason that the pacbrake is not working? I'm 600 miles from home and need my exhaust brake back!
I know someone my have the answer
