Paint for A pillar gauge mount
Beef up the front end ?
Calif members/bug deflector
Can anyone out there give me a part no. or name? That I can give to the Dodge parts man. So I can get some of this aerosal paint. To do my pillar mount. My interior is agate. I've read a couple of posts. But no one made any mention of part no. Because the parts boys here in Puyallup Wa. have never heard of it. Somebody help.
Ron
2001 2500 4x4 camper and tow package,auto,red and silver,leather (agate),Infinity stero,autometer gages,woodgrain,linex
He should have a book listing paint that he can get. You just need your year and trim color/code. It's a big grid chart. It's the same book that lists body touch up paint and such, I believe.
[This message has been edited by David Muench (edited 03-07-2001). ]
If you're referring to Larson Dodge movintruck, they have ordered it... at least two different times (that I know of)... for me. The 5 oz. spray can of Agate (interior) paint is part #82201399 (code LAZ). If they can't get it for you for some reason I have enough left to do at least one A-pillar... you are welcome to have it although, I would like to warn you in advance that the Agate interior spray paint (regardless of batch) has always been several shades too light. On my latest gauge project I decided to have a pint of custom color matched Agate paint mixed at an auto body paint shop, using my spare OE A-pillar for a guide. The match is virtually exact.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
[This message has been edited by John (edited 03-07-2001). ]
To add my $. 02, I got easily ordered a can of the 82201399 LAZ Spray Paint from Berg Dodge in Florence, OR last Sept. and the match was and is, perfect!
Maybe they got their act together. At $8 a can you can't go too wrong. I did put on about 3 coats - I've heard some guys putting on five. One can gives you more than enuf!
2001. 5 2500 SLT+, QC/LB 4x4, ETH, 6spd, 3:54 LSD, camper/tow equip. , NV241HD, Bright Silver, Snug Top, Ispro w/3 pod pillar w/tweeter, Pyro, Boost & Mag Hytec cover w/temp guage, "Plain Wrap" (no decals or emblems)
John thanks so much for your offer. But I stopped by Larson this mourning. The paint will be in tomorrow.
However if you have any suggestions on how to remove the stock a-pillar without breaking it. I would appreciate it. Also any suggestions on how to mount the thermo couple would be appreciated. Again thanks for the offer.
Ron
I can help you with that. Pull the weatherstripping down on the left side of the pillar - it's a friction fit over the sheet metal. Then get your fingers between the headliner and the top of the pillar. Pull. It will sound and feel like it's going to break, but it won't. Disconnect the harness from your tweeter before you get it to far out, you'll see the connector once you get the top of the pillar loose.
I just had a friend paint my pillar. . make sure you use a flexable primer before painting. . this will retard paint peeling! Check previous posts for GREAT info on thermocouple mounting. Hope this also helps.
2001 2500quad4X4SB auto KN Black Leather loaded Boost and EGT gauges EZ ordered
I don't know if you'd be intrested, but I found the paint for my truck at pep boys. They have a book in the store where you can match your interior paint to the paint they sell. I bought a can for my A pillar and it matches perfectly. I'm sure it's cheaper than dodge, but I just thought i'd share my experience.
cody
91 4x4, 5 speed, 3. 54 gears, pw injectors, 12cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues w/A pillar mount, straight piped 3' exhaust
