Pairing Trailer Tire Sensors
2014 Turbo Compressor Wheel
Emissions compliant tuning
Did a search and found nothing which seems odd. I have the Trailer Tire Pressure monitoring system on a new 22 3500. followed the directions in the manual and everything seemed to work ok, Set number of axles, number of tires, desired pressure, but when I hit start to begin pairing nothing happened. I hit the start button on the screen and it is supposed to pair within 3 mins for the 1st tire or give me 2 chirps of the horn signaling that it failed. Time went well over 3 mins and no chirps. Looking for some guidance from someone who has been successful with this.
Thanks,
Jeff
Ok, the truck has a provision to pair 4 trailers. I chose the 1st and when it asked me to set a target pressure the default in the window was 421psi. I could change it but as you moved through the process it would never link up with the sensors on the trailer. I tried it with the 2nd trailer in the list and this time the default was 50psi. I adjusted it to 75psi (my desired pressure) and it went through the process just fine. I don't know if trailer 1 is just dead to me, meaning i really only can pair to 3 trailers or what but this seems to be resolved.
Interesting. Might be something to ask the dealer on your next visit.
What kind of trailer wheels did you mount the sensors into?
