I have spent considerable amount of time reading about the VP44 and the lift pump problems that go along with the 24 valve motor. Seems like a lot of money and some very serious research has gone into getting a consistent flow to the pump.
I need to throw my . 02 worth in to see if parallel pumps have been tried by anyone.
Would relocating the stock pump to the tank area and adding a 2nd stock pump next to it maybe work? Wire both pumps thru a relay, with the backup pump wired thru a normal open 5 psi pressure switch downstream from the filter. Theory here being, if presssure drops, the backup pump kicks in. This plumbing setup would need check valves to keep fuel from looping back to the tank thru the backup pump. A warning light could also be wired in when the backup pump kicks in.
Maybe check valves would put to much resistance in the fuel flow.
Someone experienced with low pressure check valves can perhaps answer this. Oo. Oo.
