Getting preped to install FASS. I've been told by many that you can't or it's not possable to install a FASS in parallel with the stock elect. LP. Never been one to accept those answers, here's what I came up with.
I would appreiciate any feedback or thoughs on this!!
Theory of Operations:
Plumbing:
Simply by using 4 inline check valves and 2 tees you can isolate fuel flow from the non-operating LP automatcally.
How:
Tee the tank suction output, place a check valve on each side of the tee. One side feeds the FASS other side feeds the line to the stock LP. Then place a tee on the input side of the stock filter. ON the Filter Tee place a check valve on each feed from the pumps.
Note: The check vavle flow direction is from tank to stock filter on all check valves.
How it works:
The suction from the operating pump closes the check valve that feeds the the non-operating pump at the tank tee. Conversely the fuel pressure feeding the filter closes the check valve on the tee to non-operating pump at the filter. Thus the fuel pressure from the operating fuel system closes and isolates the non-operating system.
Electrical:
Disconnect the wire that feeds relay control signal from PCM to stock pump.
Connect the PCM side wire to a SPDT switch (common connector). Run a wire to stock pump connector from the switch. ( A pole of switch). Run a wire to FASS pump relay connector from the switch. ( B pole of switch). Switch in the A posistion runs stock pump, B posistion runs FASS pump.
Guess if you use a Single-Pole Triple Throw switch, you could have C pole not connected to anything. . That would keep the wife or anyone else for that matter from starting your truck . . lol
Pros:
Allows you to utilize the stock filter (more is better), WIO sensor, in the stock system while running the FASS.
No more fuel system LP failures and or FORD incidents.
Switch between fuel systems "in cab".
Cheap Anti-Theft system.
Cons:
Bleeding the fuel system may be an adventure.
May delay starting by the fuel pressure having to build up to close check valves. I'm thinking minimal at best.
I will get some diagrams up on the post very soon. (soon as I figure out how)
I welcome all discussion or ideas pro or con.
TIA
Cheers,
MAtt
Plumbing:
How:
How it works:
Electrical:
Pros:
Cons:
TIA
Cheers,
MAtt
