Don't have a website at this time - I've got lots of photos of our work, but I can't currently post anything because we're not public with our suspension system yet. If I have to demonstrate what we're producing to vendors etc. I have them sign non-disclosure agreements. It's just to protect our 75,000 dollar RandD investment during the "quiet period. " I can't really have everyone in TDR sign those forms, so I've just got to wait a bit. In two to three weeks we'll be on the market and I'll post photos and start advertizing. Believe me, I WANT TO SHOW YOU GUYS! I've just got to wait a bit.
I will, however, describe what we're doing. My company has designed parts that allow one to directly bolt on the "King" shock absorber to the front and rear of late model Dodge Ram 2500 and 3500 pickups. The "King" shock has a 2. 5 inch diameter body, a nitrogen-charged remote reservoir and complex shim-over-piston valving that is both position and speed sensitive. The shock rides on heim joints at both ends and is fully rebuildable and revalveable to customer tastes. These shocks are the exact shocks used by all the winning Baja race teams for the last several years. We use a special CNC machined part made from 6061 aircraft grade aluminum to mount the front shocks. It only requires minor drilling of the spring bucket. We also incoporate a computer-designed, progressive rate spring that increases front ariculation (wheel travel) by 60%. The rear shocks ride on their heims mounted with the piggy-back reservoirs facing up from the axle. Our '03 test vehicle runs 37" MTR's, has 8" of travel in front and 10" in the rear. It absolutely rips in the dirt and floats down the highway!
You can check out the dampers at at
www.kingshocks.com. My company is called T. Rex Engineering and we've been working with King on this particular system for about six months. At this point, we are exclusively Dodge diesel.
I say that our system is only for the 99-03 because we've only worked out the valving and clearance issues for these models. We valve shocks specifically for 2500 and 3500 and the 03's are totally different in terms of mass centralization etc. It takes time to get it just right. I haven't had the chance to go back farther to test if things line up correctly on the earlier models. Steering geometry, shock mounting points etc, might not be the same, so I don't want to guarantee that our system will work on every Dodge with a solid front axle. I'm not sure at this point. We're still testing. But it is likely that our system will eventually bolt right on to every 4x4 back to '94.
Hope this helps answer some questions, sorry for being so vague. I'll get pictures posted in a couple of weeks.
Kent Kroeker
T. Rex Engineering
