1995 3500 4wd dually w/mason body
I've read all the threads and tried everything to my ability. I still can't get to bottom of the problem. This truck is an electrical nightmare. I've replaced the ground strap, wire to fuel pump & solenoid taillights 2 headlight switches clearance light harnesses in the past year and I've owned the truck less than 2 years.
PROBLEM: Again the parking lamp fuse blows immediately when I was plowing:
Her's what I've so far:
1. Unplug plow=blown fuse (continued to plow with only truck headlights & transmission goes another story for another day)
2. Unplug harness for rear of truck=blown fuse
3. Unplug front parking lights & remove bulbs=blown fuse (didn't do clearance lights)
4. Check all wires(can't see all parts of wires) & relay box for corrosion to the best of my ability=blown fuse
5. Replace headlight switch again (#3)=park lamp works for 20 min then blows fuses immediately
6. Replace black/yellow wire to relay & relay next to headlight switch= blown fuse
As of now I don't know what else to do, I don't now how to read the electrical diagrams or how to use a multi-meter
And of course it is
going to snow in less than 12 hours and I need the truck for a 3 day business trip
Any help would be great thank you for your time :{ :{
And of course it is
