Parking Light short on 96 ram.. hallllp!!
I have been troubleshooting an annoying short in my parking light circuit (fuse 18), and I`m running out of options. Here's what I am experiencing. .
Lights will run fine indefinetly with truck off. . I`ve jumped up and down in the truck to simulate movement, no short.
Lights will stay on between 1-5 minutes with truck running and in motion. Fuse will pop for no reason, either sitting at a light or at 55mph down the highway. Bumps dont seem to be the problem.
Turn signals and stop lights work fine.
I`ve tracked down a bunch of wires in my service manual, and did some ohm readings, from the headlight switch black/yellow I get about 1. 6 to 2 ohms on normal run to ground. All light bulbs ck out, as do all unshielded harnesses... .
Is there something I`m missing? When I unplug the rear main harness, take out both bulbs in the front and have the headlight switch unplugged, I still have 300 ohms resistance. Shouldnt this be open?
hopefully someone has had a problem similar to this. . I`m just about to take it to an electrical shop and let them go at it. . its against my nature tho. . sigh. .
tnx in advance
-Jerry
tnx in advance
-Jerry
